here's a good example. i have a customer with a mid 60's Nova that was running 10.0 e.t.'s complaining that the back end of the car was skating all over above 120 MPH. he installed a wing and the car is now very stable at the top end. no other changes. it's also quicker with the wing than without.
That surprises me wouldn't think that is fast enough to make a difference my Duster running 9.7xx at 140 was rock solid with no wing.Only time it would wiggle was if you tried to run under 11psi in the slicks.
yes, but the Nova is lighter and has a very short wheel base.
machine shop owner and engine builder
