he bottom line is: What makes you think the charging system is bad? If your alt meter in the car shows a discharge then yes things need to be checked. If a volt meter is not showing more then 13.5-14.5, then things need to be checked. Yes, you could go to the GM style, but that's not ness. if things are checked and fixed. I, and I'm sure all Mopar owners, have had their issues with the stock charging systems for decades and they do work. Five items: Alternator, voltage regulator, wire conections (black from alt., VR field conections, bulkhead, alt. meter conection, redwire back out to battery) and battery. It's not complicated.
