What Dayclona said. Yes rarely a diode or maybe something else inside the alt is reducing it's output but k.i.s.s. that'll quickly confirm/deny the alt as the prob then let you move on to the reg/grounds etc. #1 in electrical is a good battery that's been PROPERLY load tested to confirm it's good EDIT and first it must be fully charged for a valid test as in slow charge overnight
