If you are head limited the engine will make the same power at 5% less rpm. So if it's 7500 with the 3.79, then it's 7100 with the four incher. If the heads aren't the limiting factor then you'll make 5% more power with the longer stroke.
Build the biggest shortblock you can afford.
There's a quote from Larry Widmer that goes something like this, "RPM means ruins people's motors."
R.
I dis-agree with that last statement... it makes more
power... a pro stock turns 10K+ for a reason... more
power
