Who makes pistons for 3.79?
You can get pistons from any of the companies... 3
of my engines run the 3.79 crank... my W-9 with the
3.79 uses a CP piston, my W-2 has the 3.79 with Ross
pistons... my 416 has the 4" crank with Diamond pistons
EDIT
I liked the fact that Diamond would change the compression
height on a set of pistons for $35 extra.... I think
I'll be using them more often... plus they are local
so I can pick them up
