Well, It's been a while since I have posted anything on this.After the pass I posted I got the car home & ready for winter, The part that stinks is that I went to change the oil & drained the oil out of the system 1 on the car & root beer metallic is not what you want to see. So I have basically left it untouched until now.For those of you still interested, I plan on pulling the Hemi out. I think that it may just be a rod bearing as the oil pressure was still good but the last time at the track it was not running right. I used a friends timing light and there is where I knew it wasn't happy.40deg. timing in a Hemi never works out well. So checked it with my light & it was at 35deg. My timing light has been off the whole time.Backed the timing off to 35 & that is the video you saw above.Fast forward this year…….I have a surprise in store……...
