this is on the out side edge of the bottom of #4 bore on a 400 block. I can stick a paper clip into it to about where the line is at. I have taken the drain plug out of the side of the block and shined a bright flash into it ,I don't think it goes thru but can it cause problems in the future?
Is there a fix ? is this common ?
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
