i'd clean it up with a carbide cutter & get the block magged & pressure tested. stay safe, seeya.
I am of the same thinking,,It is hard to tell from the fuzziness of the pic but is that a crack that started at a casting anomoly?
Pressure test and mag to be sure before investing time or money in it Way better to be safe than sorry Most everything is fixable, it ends up depending on how much and how hard it costs to fix it, it is probally nothing but to make sure
