Thank you for the pointers Ill check them out would it be possiable for flex plate to deflect enough to cause that problem or maybe shim converter back some it is a sfi plate but I did not measure how far I had to pull converter forward to attach to plate but it did not seem excessive.
Highly doubtful this is the issue .
