mr p,, what high angular hiem ?? reason for asking i need to channge up my steering from the stock rod ends to a hiem, and also what recomends do you have as for as a spacer, metal / aluminum??
High angular heims give you more movement so the tie
rods wont go into bind... a standard usually WILL go
into bind at full travel... thats the reason mine
broke... the high angular will give you about 12* to
18* more angle (dependent on size)... as for the spacer
alum is fine if you have enough diameter so it cant
pivot
