Thanks,guys! In actuality,the front spring mounting bolt is in the TOP hole! If I drop it down to the BOTTOM hole,will that lower the rear end ride heighth? I talked to Gary Jacob(Jake68)today,and he said that it's common with the B-Body cars with A-Body springs, to drill a new rear spring mount hole forward of the existing mounting hole...to correct the rear shackle angle! Please give me your opinions on this! THANKS! Randy B.
I think we talked about the shackle angle the other day
