jack the front of the truck up / support it under the lower control arm to take the pressure off of the suspension. Then use the air chisel to take the head off of the rivets. then drive the chisel between the ball joint and the upper arm to seperate it.( it pops right out ) then jut tap the rivets out of the arm to completely remove them
