I have my short block assembled and started mocking up the top end I am using Indy SR heads and Harland Sharp 1.5 rockers it is a solid roller with .739/.715 lift the roller starts in the middle of the valve tip and rolls to the exhaust side and stays there I know the shaft needs to come up ie shims but the radius in the rocker stand is very shallow on these heads and the shaft needs to come up about .060 any suggestions I know the Jesel stuff would fix this but too far along to change to pushrod oiling and I am not a fan of spraybar valve covers has anyone milled the stands off and made taller ones and retained the shaft oiling? Looking for ideas any help would be great
