Certainly starting to sound like a head specific problem for sure. You have a set that fits fine, so obviously the H/S do work fine on these heads, just not that particular pair. You'll be needing to do a little minor custom work it appears.
The Cranes fit standard iron heads fine, and some Edelbrocks fine, but they too need to be changed. I have spoke to Crane about this, but its not on the immediate " to do" list". H/s will make semi customs as well by moving some of the components for you, as will T&D.
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
