Re: Indy SR heads Geometry isuue (long)
[Re: biff426]
#1033799
07/16/11 10:28 PM
07/16/11 10:28 PM
Posts: 2,091 Delray beach, Florida
Performance Only
this is the exact reason we manufacture solid billet aluminum spacers with the correct taper to fit the shaft and rocker stands. when used with good billet hold downs and studs you can correct the geometry with up to .120" thick spacers. i highly recommend you don't try stacking conventional shims.
machine shop owner and engine builder
[Re: biff426]
#1033800
07/16/11 10:38 PM
07/16/11 10:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You can have some blocks made easy enough, even with the oiling hole then mill off the stands to the needed height ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Performance Only]
#1033801
07/16/11 10:45 PM
07/16/11 10:45 PM
Posts: 936 Deland, Florida
biff426
Deland, Florida
[Re: biff426]
#1033802
07/16/11 11:24 PM
07/16/11 11:24 PM
??? Starts in the middle and as lift progresses moves to the exhaust side? Don't the tips need a lash cap as things need to go the other way?????? Mark the tip of the valve with felt tip pen and then just slide the rocker back and forth so the wheel will mark the tip and show exactly where it starts from.
[Re: biff426]
#1033803
07/16/11 11:25 PM
07/16/11 11:25 PM
Posts: 31,082 Oregon
AndyF
You can get blocks made up, or you can change rocker arms. A different brand of rocker arms will work better on those heads.
I covered this subject in my book. The mfgs make rocker arms in all different lengths. HS makes their rocker arms really long. Put a shorter rocker arm on there and you won't need to mess with shims or welding or blocks.
(crabman is correct, you need shorter rocker arms not shims. You need to sink the rocker shafts into the head rather than raise them.)
[Re: biff426]
#1033807
07/17/11 12:22 PM
07/17/11 12:22 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Are these new SR's? Has anything been done to them? Are you sure someone hasnt changed valves etc? Typically H/S rocker arms fit very well on SR's, so I would question valve lengths etc.When you have the parts mocked up, how much adjuster screw thread is sticking out bottom of rocker? Maybe you have something strange going on, but like mentioned, I have a lot of SR headed combos out there without this problem WITH H/S too. Its more a problem on Ebrocks than SRs and that even has been resolved.
RIP Monte Smith
[Re: biff426]
#1033809
07/17/11 12:48 PM
07/17/11 12:48 PM
AndyF
I keep a collection of different rocker arms on hand so I can quickly check the geometry on new combinations. Crane rocker arms are the shortest and HS are the longest. If you bought one pair of Crane rocker arms that you give you a good comparison to what you have on there now.
T&D should fit correct on the SR heads but they are expensive. It isn't that easy to buy just a pair for checking becuase they use a smaller shaft size.
In the picture I posted the plain aluminum rocker arm is from Hughes. The Hughes rocker arm is mid-length. It is shorter than HS and longer than Crane. You might buy a couple of them just to check the geometry on your heads.
[Re: biff426]
#1033811
07/17/11 01:47 PM
07/17/11 01:47 PM
CompWedgeEngines
Syracuse,NY
Certainly starting to sound like a head specific problem for sure. You have a set that fits fine, so obviously the H/S do work fine on these heads, just not that particular pair. You'll be needing to do a little minor custom work it appears.
The Cranes fit standard iron heads fine, and some Edelbrocks fine, but they too need to be changed. I have spoke to Crane about this, but its not on the immediate " to do" list". H/s will make semi customs as well by moving some of the components for you, as will T&D.
RIP Monte Smith
[Re: CompWedgeEngines]
#1033812
07/17/11 02:07 PM
07/17/11 02:07 PM
I bet he can slap some lash caps on and be pretty close ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: ]
#1033815
07/17/11 02:34 PM
07/17/11 02:34 PM
CompWedgeEngines
Syracuse,NY
I thought he mentioned lash caps, but apparently not...my bad....sounds like he may be close enough with them.
Too many people get way to " nervous" about running lash caps. If you do proper maintenance, they are trouble free. I run them on the higher lapped cars ( 300+ passes a year) and anything with a little higher spring pressure. You definately notice the better stem tip wear on the valves that use them.
We run ther one piece locking caps on the blown alky motors, and they work excellent, but quite a different application. I'm way more concerned with putting properly fitting locks and retainers on , than I am with lash caps. There are a lot of poor fitting locks out there.
RIP Monte Smith
