Definetly check the wiring harness that runs the length of the steering column. I had that same problem about ten years ago; no stop or turn signals at rear taillights. I discoverd by pressing on the wire harnes on the steering column that the rear turn signals and stoplamps were working. Turned out to be a loos connction at the pigtail.
