Finally got the trans pulled out and opened up tonight....
Found front clutches(5)were burnt....so were rear clutches(4)
I made 5 passes on the car with the fastest going 128mph in the 1/8th..so it was making some steam but not wicked up like I want to be able to....
This was the 1st time out after replacing the stripped aluminum drum with a steel, cluthes then looked good....
I test fit a 7 cluth red alto in the front drum tonight and had .070....
also test a 5 clutch rear setup and had 0 clearnaced....got to do a little work to get the .025 minimum...
probably looking to put a brake in the trans since I have it out and tore down....any recomendations....anyone use the tranzact nitro brake with the increased line pressure?
