my 440's almost exactly same as your specs. i was deciding between the Comp XE cams and ended up going with the XE268 because i have an auto and didn't want to get into changing the converter - probably still could've went with a bit more cam, so the 275's probably a good choice
'71 Satellite Sebring 440
