The arms are flat so the angle has no effect on water flow. The flow direction is determined by which way the pump is turned. The different angles are not for reverse rotation Marine motors. Marine motors do not use OEM pumps, they are raw water cooled and have a seperate water pump, Sherwood pumps were common on Chrysler Marine 440s.
