.... I could not find the brtks or hardware to bolt the bar to the k-frame, so I got a set from energy suspension p/n 9.5160G, 15/16" dia greaseable bushings with the brkts. If I put the bar up with the end links first, the holes in the k-frame don't line up the bar/brkts at all, unless the bushings are suppose to be on the bend in the bar?
I'd get the sway bar loosely hooked to the k-member first. Then do the sway bar end links very loosely if possible. Then lower it on the ground. With the car off the ground the sweep of the LCA will tug on the end links making it very hard to tighten up. Especially if they are polys. You may have to adjust the height of the end link so you don't get too much bind at ride height.
Those black plates in my picture above are adapter brackets. Do you have something like that in your kit from Energy? Only two bolts hold that in. The adapter should bolt to two holes in the K-member. Holes should look like this.
