I'm in the middle of a front suspension upgrade with viper calipers, bigger torsion bars (from a 68 RR), boxed lca's, and a sway bar. The bar is from a '68 RR 383 4bbl car (.94 dia). I am installing the bar on my '67 Coronet which didn't have a sway bar to begin with. What I need is the proper location to mount the brackets and bushings on the k-frame. There is a hole at each end of the k-frame, on the fwd side lip that I think is where the fwd bolts go. Is this correct?
Mopar or no car
MoPar=Massivly Over Powered And Respected!
'93 W250 Ram
'68 Charger
'67 Coronet 500 my steet/strip rod-now a 6BBL!
