Trumbull,CT.
you cannot use a predator head,, and you cannot use a millenium head or any stage v head for that matter
if you want to run ss/am, or a/sma,, you need to run parts with numbers from mopar
a/sm and ss/am stuff that are fast are small blocks,, but i dont think you can get there with a small block without alot of money,,, the p-5 hemi is dead since there are no "new" available head castings
your best bet is to get a hemi 99 and destroke it some,, run it like that then build a new one with a small bore,, and build a 420 inch motor or so
if youre serious about this i may build one over fall/winter,, i can share ideas with you if you are doing one too
lloyd wofford has a b/sma stratus that has a patterson 358 p-5 hemi in it,, it make 950 or so and runs about .45 under,,, since there are no parts available to build a "better" motor,, there are thoughts to build a hemi 99 around 400 inches for it,, and move to a/sma
jeff
Jeff, MBE has ads for P-5 stuff on their site. Maybe the castings are from down-under.
