if the pistons are fine/etc then just get the journals ground down as little as you can (say 0.010?) new undersized bearings and go. Swap to a COMP XE 285HL (241/247 @ .050, 110 LSA, .545/.545 lift) or voodoo 60305 cam (242/252, 110 LSA, and .533/.552 lift) and it'll probably run pretty every bit as good as you'd hope a stroker would for a LOT less coin (IE broader powerband, more peak power than the .509 cammed 440, better idle/driveability/etc)
That being said, a stroker would still make for a better engine with some decent heads and an even larger cam...but since you spent the money once, it's up to you to justify spending it again for the benefits.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph 1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD) 1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD) 1989 Shelby CSX #500/500
