headlight question #3274472
12/06/24 05:49 PM
12/06/24 05:49 PM
Ontario, Canada
Stanton Online content OP
Don't question me!
Stanton  Online Content OP
Don't question me!
Ontario, Canada
In a 4-light system do the low beams go off when the hi beams are on ??
Re: headlight question [Re: Stanton] #3274481
12/06/24 06:27 PM
12/06/24 06:27 PM
Andrewh Offline
Andrewh  Offline
not on any I have owned.
the low beams have high beams in them as well, and all 4 are on when on high beams.
Re: headlight question [Re: Andrewh] #3274500
12/06/24 08:26 PM
12/06/24 08:26 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, all 4 are lit on "high" - high beams will have 2 terminals, low beams 3.
Re: headlight question [Re: Stanton] #3274517
12/06/24 09:41 PM
12/06/24 09:41 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Are you asking if the low beam filaments are still lit when you have the high beams on? If so, no.
Re: headlight question [Re: Sniper] #3274536
12/06/24 11:12 PM
12/06/24 11:12 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Quote
Yes and thank you.
Re: headlight question [Re: Sniper] #3274543
12/07/24 05:53 AM
12/07/24 05:53 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
to further clarify.
there are 2 filaments inside a low beam bulb. a low beam filament and a high beam filament. this is why they have 3 electrical tabs on them. high beams only have 1 filament inside the bulb and 2 electrical tabs on the back of the bulb.
perception is 90% of reality
Re: headlight question [Re: Stanton] #3274746
12/08/24 05:13 AM
12/08/24 05:13 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Yes…
The power from floor selector switch is only routed from the light green wire coming from headlights switch to one of the circuits… violet which is low beam and red which is high beams. Once you select High beams energizing red wire, there is no power on violet circuit.
Re: headlight question [Re: NachoRT74] #3274928
12/08/24 11:00 PM
12/08/24 11:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
NachoRT74 you are right on the wiring I read the post differently.
Re: headlight question [Re: stumpy] #3274930
12/08/24 11:04 PM
12/08/24 11:04 PM
CA
crackedback Offline
crackedback  Offline
CA
Originally Posted by stumpy
NachoRT74 I think you maybe mistaken. That is why low beams have three terminals and highs have two.
He isn't wrong. Exactly how the factory system works.
Two filaments in a low beam headlight. One for low, other for high. Both are not on at the same time. They have different reflective points in the housing which changes light output area.
Re: headlight question [Re: crackedback] #3274942
12/09/24 02:37 AM
12/09/24 02:37 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The reason there are only 3 wires to the low beam light instead of 4 wires is because both the high beam and the low beam elements in the low beam light both use a common ground.
The high beam light only has the high beam circuit power and a ground.
The dimmer switch determines if the high beam circuit or the low beam circuit has power to it.
All of the lighting in the front of the car share the same ground circuit.
Re: headlight question [Re: poorboy] #3274988
12/09/24 10:19 AM
12/09/24 10:19 AM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
I got the correct answer from SNIPER in the third reply - but you guys have turned this into a "my dick's bigger than your dick" thread !!
One thing I will mention though ...
I've just finished making a complete 4-light harness to incorporate relays. I know CRACKEDBACK makes and sells these but I like to build my own stuff - I can make things to fit the way I want them. According to other posts he makes a good product. So having finished mine I can tell you that his are worth every dime he sells them for - MORE in my opinion. By the time you buy all the wire, terminals, heat shrink, wire cover, relays, etc and add a few hours labor, his units are a bargain!
Re: headlight question [Re: Stanton] #3275011
12/09/24 11:50 AM
12/09/24 11:50 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Nobody has turned this post into a dick size debate but you. It is known as a learning process. My point was that all four bulbs are on in high beam. Which is the way I read your post and I wasn't the only one.
Re: headlight question [Re: poorboy] #3275042
12/09/24 01:24 PM
12/09/24 01:24 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Forgot to mention that.
Of course common ground wire and also one of each filament legs to a common prong.
Re: headlight question [Re: Stanton] #3275045
12/09/24 01:28 PM
12/09/24 01:28 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Not really, just being detailed on the info, preventing maybe future questions.
At least on my side answers shruggy
Re: headlight question [Re: Stanton] #3275125
12/09/24 06:05 PM
12/09/24 06:05 PM
CA
crackedback Offline
crackedback  Offline
CA
Thank you for the comment. up
Time is money type deal.
Re: headlight question [Re: crackedback] #3275155
12/09/24 08:25 PM
12/09/24 08:25 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
I understand some guys want to modify the mopar OE wiring system in order to increase the headlight brightness but..
My solution was to go to LEDs which only draw about 25% of the current required for the OE incadescents, and since
LEDs depend more on current than voltage they have greater brightness. Also LEDs tend to have a wider dispersion output
so one can actually run (4) low beams without any issues. For my 70 RR, I fabricated a Y harness using Amazon ceramic connectors
and have (4) low or (4) high beams by wiring both dual filament LED headlights in parallel. An EZ solution without having to add relays and revise the
mopar factory wiring...
As per the attached photo.
Just my $0.02... wink
