Re: headlight question
[Re: Stanton]
#3274517
12/06/24 09:41 PM
12/06/24 09:41 PM
Posts: 6,636 nowhere
Sniper
nowhere
In a 4-light system do the low beams go off when the hi beams are on ?? Are you asking if the low beam filaments are still lit when you have the high beams on? If so, no.
[Re: Sniper]
#3274536
12/06/24 11:12 PM
12/06/24 11:12 PM
Posts: 9,172 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Are you asking if the low beam filaments are still lit when you have the high beams on? If so, no. Yes and thank you.
[Re: Sniper]
#3274543
12/07/24 05:53 AM
12/07/24 05:53 AM
Posts: 5,001 new berlin wisconsin
Mr T2U
In a 4-light system do the low beams go off when the hi beams are on ?? Are you asking if the low beam filaments are still lit when you have the high beams on? If so, no. to further clarify. there are 2 filaments inside a low beam bulb. a low beam filament and a high beam filament. this is why they have 3 electrical tabs on them. high beams only have 1 filament inside the bulb and 2 electrical tabs on the back of the bulb.
perception is 90% of reality
[Re: Stanton]
#3274746
12/08/24 05:13 AM
12/08/24 05:13 AM
Posts: 6,138 Valencia, España
NachoRT74
Valencia, España
In a 4-light system do the low beams go off when the hi beams are on ?? Yes… The power from floor selector switch is only routed from the light green wire coming from headlights switch to one of the circuits… violet which is low beam and red which is high beams. Once you select High beams energizing red wire, there is no power on violet circuit.
[Re: stumpy]
#3274930
12/08/24 11:04 PM
12/08/24 11:04 PM
Posts: 2,148 CA
crackedback
CA
NachoRT74 I think you maybe mistaken. That is why low beams have three terminals and highs have two. He isn't wrong. Exactly how the factory system works. Two filaments in a low beam headlight. One for low, other for high. Both are not on at the same time. They have different reflective points in the housing which changes light output area.
[Re: poorboy]
#3274988
12/09/24 10:19 AM
12/09/24 10:19 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I got the correct answer from SNIPER in the third reply - but you guys have turned this into a "my dick's bigger than your dick" thread !!
One thing I will mention though ...
I've just finished making a complete 4-light harness to incorporate relays. I know CRACKEDBACK makes and sells these but I like to build my own stuff - I can make things to fit the way I want them. According to other posts he makes a good product. So having finished mine I can tell you that his are worth every dime he sells them for - MORE in my opinion. By the time you buy all the wire, terminals, heat shrink, wire cover, relays, etc and add a few hours labor, his units are a bargain!
[Re: poorboy]
#3275042
12/09/24 01:24 PM
12/09/24 01:24 PM
NachoRT74
Valencia, España
The reason there are only 3 wires to the low beam light instead of 4 wires is because both the high beam and the low beam elements in the low beam light both use a common ground. The high beam light only has the high beam circuit power and a ground.
The dimmer switch determines if the high beam circuit or the low beam circuit has power to it.
All of the lighting in the front of the car share the same ground circuit. Forgot to mention that. Of course common ground wire and also one of each filament legs to a common prong.
[Re: Stanton]
#3275045
12/09/24 01:28 PM
12/09/24 01:28 PM
NachoRT74
Valencia, España
I got the correct answer from SNIPER in the third reply - but you guys have turned this into a "my dick's bigger than your dick" thread !! Not really, just being detailed on the info, preventing maybe future questions. At least on my side answers
[Re: Stanton]
#3275125
12/09/24 06:05 PM
12/09/24 06:05 PM
Posts: 2,148 CA
crackedback
CA
I've just finished making a complete 4-light harness to incorporate relays. I know CRACKEDBACK makes and sells these but I like to build my own stuff - I can make things to fit the way I want them. According to other posts he makes a good product. So having finished mine I can tell you that his are worth every dime he sells them for - MORE in my opinion. By the time you buy all the wire, terminals, heat shrink, wire cover, relays, etc and add a few hours labor, his units are a bargain! Thank you for the comment. Time is money type deal.
[Re: crackedback]
#3275155
12/09/24 08:25 PM
12/09/24 08:25 PM
Posts: 5,481 So Cal
Sinitro
So Cal
I understand some guys want to modify the mopar OE wiring system in order to increase the headlight brightness but.. My solution was to go to LEDs which only draw about 25% of the current required for the OE incadescents, and since LEDs depend more on current than voltage they have greater brightness. Also LEDs tend to have a wider dispersion output so one can actually run (4) low beams without any issues. For my 70 RR, I fabricated a Y harness using Amazon ceramic connectors and have (4) low or (4) high beams by wiring both dual filament LED headlights in parallel. An EZ solution without having to add relays and revise the mopar factory wiring... As per the attached photo. Just my $0.02...
