Helper electric fuel pumps #3273985
12/04/24 05:53 AM
12/04/24 05:53 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I had a helper fuel pump on my Cuda years ago. It was a low pressure pump installed close to the tank that I only to prime my carbs for a better starting. The gas evaporates in the bowls in between drives now days and extra cranking is not something I prefer. I just don’t want to leave it on and would like one that will not impede the stock fuel pump flow when off. Anyone have a pump they like to use?
Re: Helper electric fuel pumps [Re: fastmark] #3274007
12/04/24 09:18 AM
12/04/24 09:18 AM
Benton, IL.
DaveRS23 Offline
Master of nothing...
DaveRS23  Offline
Benton, IL.
I use a Holley gerotor. I have it hooked to a switch under the dash for manual operation and have a micro switch on the Dominator's secondaries. Most of the time, the car runs on the mechanical pump. The electric is used for priming and for full throttle. The mechanical pulls through the electric gerotor just fine.
Master, again and still
Re: Helper electric fuel pumps [Re: DaveRS23] #3274010
12/04/24 09:31 AM
12/04/24 09:31 AM
Star Idaho
67vertman Online rolleyes
67vertman  Online Rolleyes
Star Idaho
I am not a fan of the Clicity Clack fuel pumps, they are prone to failure.
That said, you could wire it to a start power wire, so it would only come on when you are cranking the engine. The only other option is to wire it to a switch.
Or, buy an electric pump and put a pressure regulator in line.
My Monster are real!
Living within your means makes life pretty easy.
Re: Helper electric fuel pumps [Re: 67vertman] #3274018
12/04/24 10:28 AM
12/04/24 10:28 AM
Benton, IL.
DaveRS23 Offline
DaveRS23  Offline
Benton, IL.
I am not sure what you mean by "Clicity Clack fuel pump".
But if you wire the electric pump to the start circuit, you would still have to crank the engine until the carb is full. That may be a little faster than doing the same thing with the mechanical pump, but would still require more cranking time than with other methods.
Re: Helper electric fuel pumps [Re: 67vertman] #3274024
12/04/24 10:35 AM
12/04/24 10:35 AM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
I mounted one of the ‘clickty clacks’ one right under alternator on the 65. For now I touch the red wire to alt hot stud till it fills up the clear filter (I’ll do a ground switch later with red wire hooked to alt) starts and runs great with no fuel restrictions. They make a cheap one for my Gator with 5/16” in-out lines for $18 off Amazon. The Carter pump will work too back at tank, run hot wire to a light wire (hot source) and ground up to dash, pull on lights then push button. Only on with button, No power drop that way. If you want it to run it continuously use a starter relay instead, if no battery in trunk a heavy wire is needed from front, small wire to activate. Many ways to work it
Re: Helper electric fuel pumps [Re: cudaman1969] #3274032
12/04/24 10:59 AM
12/04/24 10:59 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I used a Carter P4070 for years and had no issues. I currently keep one around for transferring gas from tank to gas cans and back when i need to.
Time just gets away from us
I`m here until I`m not
Re: Helper electric fuel pumps [Re: fastmark] #3274036
12/04/24 11:20 AM
12/04/24 11:20 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
You can wire your relay to an oil pressure switch, so you don't have to worry about forgetting to shut it off. It will run when the key is turned on, and it will turn off when the oile pressure reaches the limit on the switch you use.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's
1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: Helper electric fuel pumps [Re: jbc426] #3274046
12/04/24 12:09 PM
12/04/24 12:09 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Ran one forever on a few street/strip cars that had 1/2" fuel lines.
Just had a switch for it, worked well for priming, didn't have to run it all the time (cars retained mech pumps).
I use a regulator any time there's an added.
Re: Helper electric fuel pumps [Re: mopars4ever] #3274052
12/04/24 12:22 PM
12/04/24 12:22 PM
moparx  Offline
i have a carter pump as well, and use it to transfer gas as the above.
Re: Helper electric fuel pumps [Re: fastmark] #3274054
12/04/24 12:27 PM
12/04/24 12:27 PM
John_Kunkel Offline
John_Kunkel  Offline
The Airtex 8016S specifies "it can be used as a priming pump that a mechanical pump can pull through when not in use."
Re: Helper electric fuel pumps [Re: John_Kunkel] #3274058
12/04/24 12:38 PM
12/04/24 12:38 PM
central il.
second 70 Offline
second 70  Offline
central il.
John do you know if they make a 3/8" version?
Re: Helper electric fuel pumps [Re: second 70] #3274068
12/04/24 01:33 PM
12/04/24 01:33 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Not sure on the brand I used a few years back but it was like the one you showed and it didn`t last long at all. Threw it in the trash.
Re: Helper electric fuel pumps [Re: mopars4ever] #3274071
12/04/24 01:55 PM
12/04/24 01:55 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Re: Helper electric fuel pumps [Re: Neil] #3274109
12/04/24 04:55 PM
12/04/24 04:55 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
For filling the bowls, I use an eyedropper or a plastic squeeze bottle like what you'd sometimes see for mustard/ketchup.
My squeeze bottle's dedicated for gasoline, been using it for years with no problems.
Some folks don't want to pull the air cleaner to prime the carb, which is where the electric pump is handy.
I've used the Carter (72 GPH, IIRC) and Holley 110 pumps with mech pumps, no problems.
Re: Helper electric fuel pumps [Re: Neil] #3274113
12/04/24 05:49 PM
12/04/24 05:49 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Good point here (albeit a manual effort one), as it happens I literally do this with my Carter TQ 9800 carb, and while this works great I still find it exceedingly annoying when this is required even after the car sits there for a mere two weeks!!! yikes... shruggy
Sort of have been thinking of replacing that manual effort with an automated "give it a bowl re-fill" solution.
