Re: Helper electric fuel pumps
[Re: fastmark]
#3274007
12/04/24 09:18 AM
12/04/24 09:18 AM
Posts: 13,129 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
I use a Holley gerotor. I have it hooked to a switch under the dash for manual operation and have a micro switch on the Dominator's secondaries. Most of the time, the car runs on the mechanical pump. The electric is used for priming and for full throttle. The mechanical pulls through the electric gerotor just fine.
Master, again and still
[Re: DaveRS23]
#3274010
12/04/24 09:31 AM
12/04/24 09:31 AM
Posts: 5,615 Star Idaho
67vertman
Star Idaho
I am not a fan of the Clicity Clack fuel pumps, they are prone to failure.
That said, you could wire it to a start power wire, so it would only come on when you are cranking the engine. The only other option is to wire it to a switch.
Or, buy an electric pump and put a pressure regulator in line.
My Monster are real!
Living within your means makes life pretty easy.
[Re: 67vertman]
#3274018
12/04/24 10:28 AM
12/04/24 10:28 AM
DaveRS23
Benton, IL.
I am not sure what you mean by "Clicity Clack fuel pump".
But if you wire the electric pump to the start circuit, you would still have to crank the engine until the carb is full. That may be a little faster than doing the same thing with the mechanical pump, but would still require more cranking time than with other methods.
[Re: 67vertman]
#3274024
12/04/24 10:35 AM
12/04/24 10:35 AM
Posts: 8,876 fredericksburg,va
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
I mounted one of the ‘clickty clacks’ one right under alternator on the 65. For now I touch the red wire to alt hot stud till it fills up the clear filter (I’ll do a ground switch later with red wire hooked to alt) starts and runs great with no fuel restrictions. They make a cheap one for my Gator with 5/16” in-out lines for $18 off Amazon. The Carter pump will work too back at tank, run hot wire to a light wire (hot source) and ground up to dash, pull on lights then push button. Only on with button, No power drop that way. If you want it to run it continuously use a starter relay instead, if no battery in trunk a heavy wire is needed from front, small wire to activate. Many ways to work it
[Re: cudaman1969]
#3274032
12/04/24 10:59 AM
12/04/24 10:59 AM
Posts: 13,746 md
mopars4ever
md
I used a Carter P4070 for years and had no issues. I currently keep one around for transferring gas from tank to gas cans and back when i need to.
Time just gets away from us I`m here until I`m not
[Re: fastmark]
#3274036
12/04/24 11:20 AM
12/04/24 11:20 AM
Posts: 3,309 West Coast, USA
jbc426
West Coast, USA
You can wire your relay to an oil pressure switch, so you don't have to worry about forgetting to shut it off. It will run when the key is turned on, and it will turn off when the oile pressure reaches the limit on the switch you use.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: fastmark]
#3274054
12/04/24 12:27 PM
12/04/24 12:27 PM
Posts: 27,015 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I just don’t want to leave it on and would like one that will not impede the stock fuel pump flow when off. Anyone have a pump they like to use? The Airtex 8016S specifies "it can be used as a priming pump that a mechanical pump can pull through when not in use."
[Re: John_Kunkel]
#3274058
12/04/24 12:38 PM
12/04/24 12:38 PM
Posts: 1,753 central il.
second 70
central il.
I just don’t want to leave it on and would like one that will not impede the stock fuel pump flow when off. Anyone have a pump they like to use? The Airtex 8016S specifies "it can be used as a priming pump that a mechanical pump can pull through when not in use." John do you know if they make a 3/8" version?
[Re: second 70]
#3274068
12/04/24 01:33 PM
12/04/24 01:33 PM
Posts: 13,746 md
mopars4ever
md
I just don’t want to leave it on and would like one that will not impede the stock fuel pump flow when off. Anyone have a pump they like to use? The Airtex 8016S specifies "it can be used as a priming pump that a mechanical pump can pull through when not in use." John do you know if they make a 3/8" version? Not sure on the brand I used a few years back but it was like the one you showed and it didn`t last long at all. Threw it in the trash.
