Sleeve in a Hemi block #3272800
11/27/24 06:51 PM
11/27/24 06:51 PM
fredericksburg,va
cudaman1969 Offline OP
Itch Nutz
Itch Nutz
fredericksburg,va
I need one for #3 cylinder bored .060 over, any problems in doing this? 66 block. I’ve heard the walls are thicker on Hemi blocks, true? Has a small hairline crack on side of cylinder looking at the pin. I pressure tested it to 30psi and a tiny bubble weeped out, hoping a sleeve will fix it. No idea the history on this block.
Re: Sleeve in a Hemi block [Re: cudaman1969] #3272802
11/27/24 07:07 PM
11/27/24 07:07 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Shouldn't be a problem. I sleeved one like that. Well, much worse, it froze and busted. But everything turned out fine. I don't know if the walls are any thicker. Should be an easy job.
2011 Drag Pak Challenger
Re: Sleeve in a Hemi block [Re: cudaman1969] #3272816
11/27/24 07:39 PM
11/27/24 07:39 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
The motor I run now is sleeved. +.060, I've run it for over ten years. The fastest motor I ever had in the car had 8 sleeves. No issue.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: Sleeve in a Hemi block [Re: Steve1118] #3272830
11/27/24 08:49 PM
11/27/24 08:49 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My mega block is sleeved. Had a 3" crack when it kicked a rod. Absolutly no problems over 3 years close to 300 passes.
Doug
Re: Sleeve in a Hemi block [Re: dvw] #3272840
11/27/24 10:03 PM
11/27/24 10:03 PM
fredericksburg,va
Itch Nutz
Itch Nutz
fredericksburg,va
Excellent.
Re: Sleeve in a Hemi block [Re: cudaman1969] #3272864
11/28/24 03:15 AM
11/28/24 03:15 AM
The results you will get depends on how good the machine shop is on installing it and what type and material the sleeve is twocents
if they a standard rebuilders sleeve and bore the block ,004 or smaller than the outside diameter of the sleeve and then drive it in with a BFH it will more than likely need boring or some honing to get it useable.
If they use a ductile iron sleeve and bore the block.003 or smaller than the O.D. of the sleeve and then chill the sleeve in a freezer so it shrinks and almost falls into the block and heat up the 3 cylinder in the block, the sleeve cylinder and both of the ones next to it will take less machine work to make it work well up scope twocents
Good luck either way luck
Re: Sleeve in a Hemi block [Re: rickseeman] #3273547
12/02/24 09:14 AM
12/02/24 09:14 AM
an8sec70cuda Offline
iagree No problem at all. People always get scared of sleeves, but I'd run one in a heartbeat.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: Sleeve in a Hemi block [Re: an8sec70cuda] #3273607
12/02/24 12:25 PM
12/02/24 12:25 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
If done right it will be the best cylinder in the block.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Sleeve in a Hemi block [Re: W.I.N. Racing] #3273635
12/02/24 01:18 PM
12/02/24 01:18 PM
Enjoy life today, It has an ex...
gtx6970 Offline
gtx6970  Offline
Mine has one maybe 2 sleeved cyl.
No issues
Enjoy life today, It has an expiration date
Re: Sleeve in a Hemi block [Re: gtx6970] #3273694
12/02/24 05:21 PM
12/02/24 05:21 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I had one we saved, and it had all 8 sleeved...Ran really good in my car at 484 cubes at +.060, and for many years. Was a little beast...Till I torched a head gasket and broke a main cap. Put new Pro-Gram Billet caps in, line bored and honed it, and sold it.
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
Re: Sleeve in a Hemi block [Re: Dragula] #3273700
12/02/24 05:54 PM
12/02/24 05:54 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Most R3s I know of have sleeves. It's almost a rite of passage for them🤣. I'd sleeve every iron block cylinder if I could afford it
Re: Sleeve in a Hemi block [Re: Hot 340] #3273761
12/02/24 10:23 PM
12/02/24 10:23 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have racing buddies that we have sleeved all 8 holes with no issues.
1970 Challenger R/T, 528 Hemi
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Sleeve in a Hemi block [Re: cudaman1969] #3273974
12/04/24 12:24 AM
12/04/24 12:24 AM
If I was you and don't know if the shop you want to sleeve cylinder #3 knows how to do that so it doesn't make cylinders #1 and #5 go out of round I would have them sleeve all four cylinders on the drivers side before starting the final machine work of boring ad honing them twocents
If you know and trust that they can install the # 3 sleeve without affecting the two adjacent cylinders roundness when they are done go forward with them scope work up
Good luck, either way up luck
