Listing my 2024 build motor to upgrade bigger and better. INDY 440-1 cnc "plus" heads with upgraded machining for TD paired rockers, steel thread inserts and doweled. NEW. Guides were replaced before heads were ever ran etc. NEW 22? passes ago. Manton stage5 pushrods Red zone PR oiling lifters .937 offset intakes. Ti 2.25 intake valves PSI springs. Cometic 4.53" head gaskets. Custom 55mm 4/7 swap cam from Scott Brown. Heads are about 60cc now. Indy first design 2x4 tunnelram with misc plenum spacers. Choice of '830' cfm or '1000' cfm carbs. Linkage, fuel lines regulator etc. I also have SS 2.25 intake valves and can alter the hardware to your combo. Includes the complete balanced recipe assembly with pistons, crank, rods etc. for a low-deck with 4.505ish bore. (can be used in an RB with different length rods.) Basically you'd need a block, most the oiling system (I have a new billet pump and dist drive) and timing drive. This combo will go 8.2's at 2815lbs you can calculate power if you wish. I may separate items. $13.500 Way cheaper than new and proven good stuff. PM me or two4eight-464 twenty 4eighty5 Sean
