Re: What headlights were used on A12 cars?
[Re: WINGNUT]
#3247230
07/25/24 12:46 PM
07/25/24 12:46 PM
Posts: 21,387 A collage of whims
topside
A collage of whims
Until my most recent B-body, all of my '67-'70 Bs had General Electric-embossed, wide-fluted, headlamps. Every one factory-installed. That's 20-some cars since the '80s, various assy plants. Most recent one, a '69 RR St Louis car, 17,000 miles, has TS low-beams & the "correct" GE high beams. I assume the low beams are original - car was hardly ever used, and likely rarely with lights on - but allegedly TS & Westinghouse have been seen on a few original cars.
[Re: WINGNUT]
#3247444
07/26/24 01:10 PM
07/26/24 01:10 PM
Posts: 1,384 Back In Iowa
belv2vert66
Back In Iowa
I asked a SPECIFIC question. Do A12 cars come with GE or Westinghouse headlights. I KNOW every car with 4 head lights can come with either. If someone is restoring an A12 car, I want to offer my DATE CODED head lights to them.WINGNUT I'm no expert........but as an A12 owner, when I was looking, I would have been very interested in those headlights. As long as they are the wide flute 4001
[Re: WINGNUT]
#3247483
07/26/24 03:34 PM
07/26/24 03:34 PM
Posts: 75,265 A gulag near you.
JohnRR
A gulag near you.
Yes they are the wide flute. Above the 2-9 date code it reads SAE 69. WINGNUT I would think 2-9 is a little early for an A12 ??
Mainstream Media is the new Pravda
[Re: JohnRR]
#3247625
07/27/24 10:37 AM
07/27/24 10:37 AM
Posts: 804 BRIDGEWATER, CT.
WINGNUT
BRIDGEWATER, CT.
Yes they are the wide flute. Above the 2-9 date code it reads SAE 69. WINGNUT I would think 2-9 is a little early for an A12 ?? That is why I am asking. How can I learn if I don't ask? I have now heard from 2 A12 owners that have original high beams date coded 3-9 WINGNUT
[Re: gtx6970]
#3248588
07/31/24 12:03 PM
07/31/24 12:03 PM
WINGNUT
BRIDGEWATER, CT.
But once they are in the car , you cant read the date code anyway correct??? Correct, BUT some people are going for OE certification or are just plain anal. WINGNUT
[Re: WINGNUT]
#3248614
07/31/24 01:59 PM
07/31/24 01:59 PM
Posts: 3,158 Michigan
A727Tflite
Is the date code ink stamped on the back ?
[Re: A727Tflite]
#3248651
07/31/24 04:23 PM
07/31/24 04:23 PM
Posts: 21,724 It's a dry heat
gtx6970
It's a dry heat
I see the date code ink stamped on the back ? Readable With the bulb in the car???
[Re: WINGNUT]
#3248652
07/31/24 04:24 PM
07/31/24 04:24 PM
gtx6970
It's a dry heat
But once they are in the car , you cant read the date code anyway correct??? Correct, BUT some people are going for OE certification or are just plain anal. WINGNUT But they don't pull the bulb to ck date codes, do they????
[Re: gtx6970]
#3248656
07/31/24 05:10 PM
07/31/24 05:10 PM
A727Tflite
I see the date code ink stamped on the back ? Readable With the bulb in the car??? I corrected my post -
[Re: gtx6970]
#3248805
08/01/24 01:53 PM
08/01/24 01:53 PM
Posts: 2,640 Nashville, TN
MOPARMIKE69
Nashville, TN
If you have picture documentation of date codes and part numbers and you are being OE Certified, it goes a long way to help the car score as good as it can.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
