What headlights were used on A12 cars? #3247226
07/25/24 12:18 PM
07/25/24 12:18 PM
BRIDGEWATER, CT.
WINGNUT Offline OP
WINGNUT  Offline OP
BRIDGEWATER, CT.
I have 2 General Electric high beam headlights. Date coded 2-9. Did A12 cars have GE or Westinghouse head lights? WINGNUT
Re: What headlights were used on A12 cars? [Re: WINGNUT] #3247230
07/25/24 12:46 PM
07/25/24 12:46 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Until my most recent B-body, all of my '67-'70 Bs had General Electric-embossed, wide-fluted, headlamps.
Every one factory-installed. That's 20-some cars since the '80s, various assy plants.
Most recent one, a '69 RR St Louis car, 17,000 miles, has TS low-beams & the "correct" GE high beams.
I assume the low beams are original - car was hardly ever used, and likely rarely with lights on - but allegedly TS & Westinghouse have been seen on a few original cars.
Re: What headlights were used on A12 cars? [Re: topside] #3247275
07/25/24 03:36 PM
07/25/24 03:36 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
I believe them to be 4001 and 4002 GE wide flutes.
Re: What headlights were used on A12 cars? [Re: belv2vert66] #3247281
07/25/24 04:00 PM
07/25/24 04:00 PM
BRIDGEWATER, CT.
WINGNUT Offline OP
WINGNUT  Offline OP
BRIDGEWATER, CT.
So the 2 head lights I have, (date coded 2-9) could have come from an A12 car? WINGNUT
Re: What headlights were used on A12 cars? [Re: WINGNUT] #3247284
07/25/24 04:12 PM
07/25/24 04:12 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Sure - or a Slant 6 4-door, or pretty much anything with 4 headlamps.
Stuff like headlamps were probably in large supply, so date codes won't necessarily prove anything, unless dated after the car left the plant, right ?
Re: What headlights were used on A12 cars? [Re: topside] #3247303
07/25/24 06:42 PM
07/25/24 06:42 PM
BRIDGEWATER, CT.
WINGNUT Offline OP
WINGNUT  Offline OP
BRIDGEWATER, CT.
I asked a SPECIFIC question. Do A12 cars come with GE or Westinghouse headlights. I KNOW every car with 4 head lights can come with either. If someone is restoring an A12 car, I want to
offer my DATE CODED head lights to them.WINGNUT
Re: What headlights were used on A12 cars? [Re: WINGNUT] #3247444
07/26/24 01:10 PM
07/26/24 01:10 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
I'm no expert........but as an A12 owner, when I was looking, I would have been very interested in those headlights. As long as they are the wide flute 4001
Re: What headlights were used on A12 cars? [Re: belv2vert66] #3247453
07/26/24 01:35 PM
07/26/24 01:35 PM
BRIDGEWATER, CT.
WINGNUT Offline OP
WINGNUT  Offline OP
BRIDGEWATER, CT.
Yes they are the wide flute. Above the 2-9 date code it reads SAE 69. WINGNUT
Re: What headlights were used on A12 cars? [Re: WINGNUT] #3247483
07/26/24 03:34 PM
07/26/24 03:34 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
I would think 2-9 is a little early for an A12 ??
Mainstream Media is the new Pravda
Re: What headlights were used on A12 cars? [Re: WINGNUT] #3247505
07/26/24 05:43 PM
07/26/24 05:43 PM
is that for a lot of money? whistling work
Re: What headlights were used on A12 cars? [Re: JohnRR] #3247625
07/27/24 10:37 AM
07/27/24 10:37 AM
BRIDGEWATER, CT.
WINGNUT Offline OP
WINGNUT  Offline OP
BRIDGEWATER, CT.
That is why I am asking. How can I learn if I don't ask? I have now heard from 2 A12 owners that have original high beams date coded 3-9 WINGNUT
Re: What headlights were used on A12 cars? [Re: WINGNUT] #3248140
07/29/24 01:24 PM
07/29/24 01:24 PM
MN
Droop69 Offline
Droop69  Offline
MN
Pete,
They would be fine for an early build A-12.
Re: What headlights were used on A12 cars? [Re: Droop69] #3248192
07/29/24 04:38 PM
07/29/24 04:38 PM
Enjoy life today, It has an ex...
gtx6970 Online content
gtx6970  Online Content
But once they are in the car , you cant read the date code anyway correct???
Enjoy life today, It has an expiration date
Re: What headlights were used on A12 cars? [Re: gtx6970] #3248588
07/31/24 12:03 PM
07/31/24 12:03 PM
BRIDGEWATER, CT.
WINGNUT Offline OP
WINGNUT  Offline OP
BRIDGEWATER, CT.
Correct, BUT some people are going for OE certification or are just plain anal. WINGNUT
Re: What headlights were used on A12 cars? [Re: WINGNUT] #3248614
07/31/24 01:59 PM
07/31/24 01:59 PM
A727Tflite Online content
A727Tflite  Online Content
Is the date code ink stamped on the back ?
Re: What headlights were used on A12 cars? [Re: A727Tflite] #3248651
07/31/24 04:23 PM
07/31/24 04:23 PM
Originally Posted by A727Tflite
I see the date code ink stamped on the back ?
Readable With the bulb in the car???
Re: What headlights were used on A12 cars? [Re: WINGNUT] #3248652
07/31/24 04:24 PM
07/31/24 04:24 PM
But they don't pull the bulb to ck date codes, do they????
Re: What headlights were used on A12 cars? [Re: gtx6970] #3248656
07/31/24 05:10 PM
07/31/24 05:10 PM
I corrected my post -
Re: What headlights were used on A12 cars? [Re: gtx6970] #3248805
08/01/24 01:53 PM
08/01/24 01:53 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
If you have picture documentation of date codes and part numbers and you are being OE Certified, it goes a long way to help the car score as good as it can.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
