Re: New Holley Single plane intake manifold
[Re: RTSE4ME]
#3149865
06/08/23 11:00 PM
06/08/23 11:00 PM
Posts: 2,255 IL
furious70
IL
back in the early days of these engines, HotRod or someone tested this style and it eeked out similar or a little better peak HP than OEM intake but the TQ was terrible everywhere but peak IIRC. I think Engine Masters or Hot Rod Garage did an episode testing the 'cheap early 5.7 carb'ed up' vs eagle OEM manifold and EFI as well.
[Re: RTSE4ME]
#3149867
06/08/23 11:18 PM
06/08/23 11:18 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
That isn't cheap but it is less that the last 4 barrel intake that I priced. I'm looking at options for a future 5.7 build and I'm considering the costs of carburetor versus EFI. That intake and a decent 750 VS carb is around $1000. Then I'd need a way to fire the spark plugs. One aftermarket setup used a different front cover with a real distributor and THAT was a spendy route to go. Using stock EFI with some stand-alone harness is probably cheaper.
[Re: furious70]
#3149882
06/08/23 11:55 PM
06/08/23 11:55 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Looks a lot better than the XV manifold, that old thing never looked like it was designed right. I am really tempted to order one of these right now for a customer I'm building a motor for...
[Re: RTSE4ME]
#3149964
06/09/23 11:13 AM
06/09/23 11:13 AM
Posts: 1,548 Michigan
Kiddart
i run the prefix on mine. we were running the Fast efi on it then went to port injection, so this is what it looks like now.
my sone did all the machine work on the intake we just have to remake the pedestals for the fuel rails when we changed to the Hellcat injectors the pedestals needed to be longer.
Thank you Kiddart
[Re: RTSE4ME]
#3150717
06/12/23 06:42 AM
06/12/23 06:42 AM
Posts: 1,111 Usa
A39Coronet
Usa
I'd like to think I had a hand in getting them to make that intake... probably not but that's what I'll tell myself...I had lengthy convos about a year ago and then maybe six months ago with their tech side about lack of offerings for these intakes aside from high-rise version. Told them the obvious, if you plan to run any sort.of hood you were out of luck.
[Re: Kern Dog]
#3166267
08/07/23 01:52 PM
08/07/23 01:52 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
That isn't cheap but it is less that the last 4 barrel intake that I priced. I'm looking at options for a future 5.7 build and I'm considering the costs of carburetor versus EFI. That intake and a decent 750 VS carb is around $1000. Then I'd need a way to fire the spark plugs. One aftermarket setup used a different front cover with a real distributor and THAT was a spendy route to go. Using stock EFI with some stand-alone harness is probably cheaper. https://www.summitracing.com/parts/...47bCAHpsmONExDAK8d4VhZ0a0iqsaArF4EALw_wcWAY cheaper than the front drive distributor deal...
