Re: PICK UP COIL ISSUE [Re: Magnumguy] #2947144
07/25/21 09:40 PM
07/25/21 09:40 PM
UPPER MICHIGAN, MARQUETTE COUN...
N
NITROUSN Offline
NITROUSN  Offline
N
Originally Posted by Magnumguy
It only does this at idle after it's been ran awhile. I started it to move it today and ran smooth as snot off a doorknob.
Someone locally suggested the ballast resistor. It has a dual one as it was converted to elect. ign. years ago. Long before I got it
Did you try to slightly choke it when it is acting up to see if it wants to smooth out???????
Re: PICK UP COIL ISSUE [Re: NITROUSN] #2947174
07/25/21 10:55 PM
07/25/21 10:55 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Oddly, I did change the ballast, and it seems to have solved the problem.
I had to use an old one I had found as all my other Magnums have a single ballast. So....... I think problem may be solved.
I did bump up the idle oh so slightly.
Thanks gang!!
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: PICK UP COIL ISSUE [Re: Magnumguy] #2947204
07/26/21 01:17 AM
07/26/21 01:17 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Thanks gang!!
Bad connection (intermittent breakup) or high resistance (low power to module) ??.
Re: PICK UP COIL ISSUE [Re: PhillyRag] #2947354
07/26/21 01:47 PM
07/26/21 01:47 PM
moparx  Offline
what did the ballast connectors look/feel like when disconnected ? did the "new" one feel like the connectors were tighter to plug on ?
Re: PICK UP COIL ISSUE [Re: moparx] #2947519
07/26/21 08:30 PM
07/26/21 08:30 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
If the fix stays,
I'm going to guess the one or both of Ballast resistors ( assuming it was a 4 pin) were breaking down internally. Raising the idle speed the alternator produce more current to compensate. It also coincides with it being OK when cold and starting right back up as the ballast is bypassed> Time will tell beer
Re: PICK UP COIL ISSUE [Re: moparx] #2947601
07/26/21 10:59 PM
07/26/21 10:59 PM
S.E.Ohio
S.E.Ohio
One on the car was only a few weeks old. Both were tight. The one on the car when I got it was from the conversion kit the original owner used, which went bad recently. Only Jesus knows how old it was. New one was a Carquest? piece I picked up. smirk
I ordered 2 MoPar OEM's from Ehrenberg today. wink
Thanks to everyone who helped out diagnosing this. I only thought ballasts went totally out when bad.
Re: PICK UP COIL ISSUE [Re: Magnumguy] #2947961
07/27/21 10:40 PM
07/27/21 10:40 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Quote
They can do that, but also have a poor connection between terminal & coil inside.
Term. are brass, coil wire (nichrome maybe) & are just crimped together.
They get hot & that connection can degrade over time.
