Brake hose routing disc conversion
#2666218
06/15/19 03:32 PM
06/15/19 03:32 PM
Posts: 1,261 Phoenix, AZ
Belvedere1
Phoenix, AZ
Does anyone have a pic of how the front brake hoses should be routed. I converted a 67 Belvedere to a late A body disc set up with sliding calipers and would like to see how the hoses are best routed. The calipers are rear hanging and I'm using a kit Dr. Diff and his hoses were included. To be more specific, how the hose is directed coming out of the caliper. On this application the hose is mounted to the lower side or bottom of the caliper. The bleed screw is still at the upper side of the caliper housing.
Re: Brake hose routing disc conversion
[Re: AndyF]
#2666275
06/15/19 06:46 PM
06/15/19 06:46 PM
Posts: 6,225 nowhere
Sniper
nowhere
Hose routing on my Doctor Diff kit was very simple. Just a loop down and to the frame. That is neither the Late A slider disc brakes nor a B body in that picture now is it?
[Re: Stanton]
#2666546
06/16/19 03:29 PM
06/16/19 03:29 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
Sorry couldn't get better pics. I have some from assembly but can't find them.
67 Coronet with 73 A Body disc brakes. Be careful - the steel tubes on mine rubbed and I had to replace one in fear of a leak and then bent it so it had enough clearance. The hoses are Wagner BH79382 - I think they are the same for both sides but not 100% sure.
67 Coronet 500 9.610 @ 139.20 mph 67 Coronet 500 (street car) 14.82 @ 94 mph 69 GTX (clone) - build in progress......
[Re: markz528]
#2666547
06/16/19 03:30 PM
06/16/19 03:30 PM
markz528
Morrow, OH
BTW - if not obvious, these pics are of the passenger side.
