Re: RB hyd Roller lifter issues?
[Re: AndyF]
#2637158
03/25/19 09:53 PM
03/25/19 09:53 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
The Comp 26915 beehives should work for most hyd roller cams. They are good to 0.600 lift. That is what is on mine. edit,, 26120 is what I am using.
[Re: CSK]
#2637273
03/26/19 10:03 AM
03/26/19 10:03 AM
Imo, the Comp conical spring 7228 and the beehive spring 26915 are not designed for the same application. The loads and rates aren’t really very close to each other.
7228- 136@1.800/399@1.200, 438lbs/in
26915- 105@1.800/293@1.200, 313lbs/in
I look at the 26915 as a spring suitable for a lighter weight valvetrain(like a small block) that’s using lobes that are very smooth.
For a typical BB Mopar hyd roller application where someone wants a beehive spring I generally use the 26120, which is 155@1.880/377@1.280, 370lbs/in.
[Re: Lee446]
#2637313
03/26/19 11:23 AM
03/26/19 11:23 AM
What are the advantages/disadvanteges of Beehive springs? I don't really know anything about them. There should be multiple threads on that topic here, or over on Speedtalk and YB. As with anything in this hobby, there is no universal answer. We’ve actually taken them out of some BBC marine builds were they just weren’t up to the job.
[Re: Lee446]
#2637333
03/26/19 12:11 PM
03/26/19 12:11 PM
If you go through the forums, just as with the hyd roller lifters...... you’ll find they are not universally loved.
[Re: fast68plymouth]
#2637337
03/26/19 12:18 PM
03/26/19 12:18 PM
CSK
Pattison Texas
For a typical BB Mopar hyd roller application where someone wants a beehive spring I generally use the 26120, which is 155@1.880/377@1.280, 370lbs/in. I'm Sorry the 26120 is what I have, brain dead moment
[Re: Lee446]
#2637347
03/26/19 12:53 PM
03/26/19 12:53 PM
Posts: 4,206 New York
polyspheric
Hydraulic should only make noise (caused by the roller leaving the lobe and landing again) when the spring pressure + lift rate exceed the hydraulic pressure in the tappet, and the plunger compresses. The lifter's leak rate may be too high, oil supply volume in the gallery too small, or viscosity or oil pressure too low. Am I missing something?
Some beehive failures are from using a light spring believing that the design simply replaces a heavier cylindrical spring. The design saves some reciprocating weight (less wire mass, smaller retainer) but the advantage is multiple progressive rate (instead of linear) - but if harmonic float isn't a problem you may not have enough pressure.
Boffin Emeritus
