1969 Charger - What is the biggest rear wheel size? #2625979
02/25/19 06:17 PM
02/25/19 06:17 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
I have a customer that wants to go with the biggest possible wheel combo for the back of his 69 Charger. He wants to go with 295/50/15 BF Goodrich tires on 15"x 10" Crager SS. First question is would they fit (stock wheel wells) and if so, what would be the best back spacing?
Thanks!!
Re: 1969 Charger - What is the biggest rear wheel size? [Re: jim6346] #2625985
02/25/19 06:26 PM
02/25/19 06:26 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I was thinking of the same size for my Doba.
Also 15X10 with 4 inch back space wheels.
Anyone know the actual size of these in inches?
I have mechanical Aptitude.
I can screw up anything.
Re: 1969 Charger - What is the biggest rear wheel size? [Re: jim6346] #2626004
02/25/19 07:12 PM
02/25/19 07:12 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
15x10 4 7/8 bs , will have to curl the outer lip.
Re: 1969 Charger - What is the biggest rear wheel size? [Re: jim6346] #2626006
02/25/19 07:16 PM
02/25/19 07:16 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
325-50-15
Re: 1969 Charger - What is the biggest rear wheel size? [Re: jim6346] #2626012
02/25/19 07:22 PM
02/25/19 07:22 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
295-50-15
Re: 1969 Charger - What is the biggest rear wheel size? [Re: jim6346] #2626025
02/25/19 07:52 PM
02/25/19 07:52 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I'm running BFG T/A 295/50/15 with 15x10 5" backspace with SS springs. No problems.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: 1969 Charger - What is the biggest rear wheel size? [Re: jim6346] #2626111
02/25/19 11:45 PM
02/25/19 11:45 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
15x10 275
Re: 1969 Charger - What is the biggest rear wheel size? [Re: jim6346] #2626180
02/26/19 02:13 AM
02/26/19 02:13 AM
chicago il usa
K
komninon Offline
komninon  Offline
K
chicago il usa
I'm running BFG T/A 295/50/15 with 15x10 5" backspace on my 68 charger lowered 1 inch still no problems
hope that helps
Re: 1969 Charger - What is the biggest rear wheel size? [Re: jim6346] #2626225
02/26/19 10:14 AM
02/26/19 10:14 AM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Thanks everyone!! Great looking cars too!!
Re: 1969 Charger - What is the biggest rear wheel size? [Re: jim6346] #2626366
02/26/19 03:56 PM
02/26/19 03:56 PM
moparx  Offline
hoosier 12.50 on 9" with 4.5 bs.
no lip moving, no rubbing.
Re: 1969 Charger - What is the biggest rear wheel size? [Re: jim6346] #2626466
02/26/19 08:47 PM
02/26/19 08:47 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You can fit a 12" wide rim in there but with that you are limited to running a tire that is no wider than the rim. The guys running a 10" wheel and a 295-50 surely notice the bulge of the tire runs wider than the rim.
I run a 18x10 with a 295-45 tire. My tire is wider than the rim but there is room for more. The problem is not just with fitment at a stand-still but during movement, up-down and cornering.
See the pictures and notice the unpainted, sorta shiny spots? That is where the tire has made contact at the outer wheel tub. Chrysler, in some strange reason, made these tubs with a strange shape. In a perfect world, the outer wheel tub would have followed the quarter panel contour to allow the wheel and tire to sit out almost flush to the edge. New cars are like this, it reduces air drag and improves fuel efficiency. In old cars, it would allow much wider tires to be used.
Re: 1969 Charger - What is the biggest rear wheel size? [Re: Kern Dog] #2648397
04/24/19 10:04 AM
04/24/19 10:04 AM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
I am having trouble finding Crager S/S's 15" x 10" with a 5" backspacing. Anyone have any luck?
Thanks,
