2.4 DOHC *update* #999431
05/24/11 11:14 PM
05/24/11 11:14 PM
Henderson Kentucky
0791challenger Offline OP
Henderson Kentucky
Had a burnt valve, replaced it cleaned the seat up. Got it all back together new timing belt and tensioner. Now it idles at about 1200 rpm with a miss, if I put my hand over the throttle body it idles down and runs smooth. Anybody have any ideas oh yeah its throwing a 2074 code which is high manifold pressure or something of that sort.
Re: 2.4 DOHC [Re: 0791challenger] #999432
05/25/11 07:37 AM
05/25/11 07:37 AM
Baltimore, MD
MadMax58 Offline
MadMax58  Offline
Baltimore, MD
Check for vacuum leaks.
Re: 2.4 DOHC [Re: MadMax58] #999433
05/25/11 08:31 PM
05/25/11 08:31 PM
Henderson Kentucky
Henderson Kentucky
One lil bitty piece of floor dry was stuck in the IAC keeping it from closing and causing the vacuum leak. I was about to go insane trying to fid the problem.
Josh
