Where to get engine wiring harness??? #999383
05/24/11 09:28 PM
05/24/11 09:28 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Who would you recommend for an engine wiring harness. Mines pretty hacked up and I would like to remove the worry. I've heard about Evans, however I don't have any experience with them (or any other electrical supplier for that matter). Also, how would you recommend cleaning the electrical block/receiver end in the firewall?
Thanks!
Re: Where to get engine wiring harness??? [Re: slowpoke] #999384
05/24/11 11:12 PM
05/24/11 11:12 PM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Other alternative is Year One who is exclusive distributor for M&H.
Cleaning the bulkhead - can use any favorite degreaser and q-tips, there is always a better way, maybe others will chime in soon. The green discoloration from terminal corrosion is typically permanent though...
Re: Where to get engine wiring harness??? [Re: slowpoke] #999385
05/24/11 11:43 PM
05/24/11 11:43 PM
Arizona
az426john Offline
az426john  Offline
Arizona
M&H makes good harness's to Year One specs which sometimes ends up being more universal than specific.
M&H will correct any problems if you are willing to pay shipping both ways. Shiping is cheap and they do a good job especially if you can also send them your old harness to use as an example.
Tuner cleaner from Radio Shack works well as a cleaner with a small wire brush.
Re: Where to get engine wiring harness??? [Re: az426john] #999386
05/25/11 01:58 AM
05/25/11 01:58 AM
Medford OR
FrankenScamp Offline
Medford OR
Had my bulkhead blocks soda blasted and replaced all the internal connectors. I redid all my wiring 1 wire at a time. Looks nice and I know all my stuff is all new.
BTW .....I'm not an electrician, it's just a very straight forward job, tidious yes, but if ya got the time it's fun
Re: Where to get engine wiring harness??? [Re: slowpoke] #999387
05/25/11 02:46 AM
05/25/11 02:46 AM
DELAWARE
bee71mopar Offline
bee71mopar  Offline
DELAWARE
Thanks!
Got mine from Evans wiring.com
Re: Where to get engine wiring harness??? [Re: ebodyseast] #999388
05/25/11 06:55 AM
05/25/11 06:55 AM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Qtips...hadn't thought of that. As far as removing from the backside, I looked under the dash and I don't think I can even touch the wires let alone remove and clean from that end. Will look again though...Any other cleaning ideas?
Thanks a lot for the replies!
Re: Where to get engine wiring harness??? [Re: slowpoke] #999389
05/25/11 01:55 PM
05/25/11 01:55 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
got mine from Kramer's really nice
Re: Where to get engine wiring harness??? [Re: slowpoke] #999390
05/26/11 12:40 AM
05/26/11 12:40 AM
Pgh, PA
Nino Offline
Nino  Offline
Pgh, PA
I got mine from Roseville Moparts. I checked all over the internet trying to find one for my 70 Coronet for a decent price, then just googled the part number and came across their site -- they had it for $115 standard, or $125 with electronic ignition.
I had low expectations because it was so cheap, but when it showed up I was quite pleased.
1970 Dodge Coronet 1968 Barracuda FB 1970 Duster 1974 Dart 1977 Dodge Custom Van
Re: Where to get engine wiring harness??? [Re: moparsquid] #999391
05/26/11 12:45 PM
05/26/11 12:45 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Kramers??? Where can I find info on them?
Re: Where to get engine wiring harness??? [Re: slowpoke] #999392
05/26/11 02:53 PM
05/26/11 02:53 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
year one no doubt. i used an evans harness and the damn thing had bad crimps all over it, drove me nuts. what a mess that thing was. just installed a year one harness in a friends car and it dropped right in and quality was top notch.
there was a thread here some where that quite a few others had the same problems i had with that evans crap.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Where to get engine wiring harness??? [Re: bee71mopar] #999393
05/26/11 06:06 PM
05/26/11 06:06 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
I got mine from Evans ten (!) years ago. I wasn't looking for a resto grade product, just something that WORKED. It has worked and held up very well, including 4yrs of daily grind when my wagon was my only means of transportation.
John
