70 manual hemi dist. shaft #999161
05/24/11 03:54 PM
05/24/11 03:54 PM
PA
BS27ROB Offline OP
BS27ROB  Offline OP
PA
Does this look like a correct shaft for a 70 hemi dist (manual), are the springs right?
Thanks, Cy
Re: 70 manual Hemi dist. shaft [Re: BS27ROB] #999162
05/24/11 06:45 PM
05/24/11 06:45 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Here is an NOS 70 Hemi manual distributors shaft and rotor. P/N 3514278
Re: 70 manual Hemi dist. shaft [Re: Snoopy] #999163
05/24/11 06:46 PM
05/24/11 06:46 PM
Snoopy Offline
Snoopy  Offline
Re: 70 manual Hemi dist. shaft [Re: Snoopy] #999164
05/24/11 06:46 PM
05/24/11 06:46 PM
Snoopy Offline
Snoopy  Offline
Bottom
Re: 70 manual Hemi dist. shaft [Re: Snoopy] #999165
05/24/11 06:53 PM
05/24/11 06:53 PM
Snoopy Offline
Snoopy  Offline
Bottom 2
Re: 70 manual Hemi dist. shaft [Re: Snoopy] #999166
05/24/11 11:59 PM
05/24/11 11:59 PM
PA
BS27ROB Offline OP
BS27ROB  Offline OP
PA
Thanks Snoopy, sure looks the same to me.
Re: 70 manual Hemi dist. shaft [Re: BS27ROB] #999167
05/25/11 12:11 AM
05/25/11 12:11 AM
Snoopy Offline
Snoopy  Offline
If you need any other pictures, I will dig it out and get them for you. I am not sure if the number stamped on the unit is exclusive to Hemi's, but I think your right about it being the same part.
Re: 70 manual Hemi dist. shaft [Re: Snoopy] #999168
05/25/11 07:53 PM
05/25/11 07:53 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Earl,it's not.I have about a half dozen big block dual point shafts,all have the same number.Only thing specific is rotor (slot length) and springs.
