Big Block Mini Starter #999059
05/24/11 03:08 PM
05/24/11 03:08 PM
Canada
Max Weg Offline OP
Max Weg  Offline OP
Canada
Hi,
Does anyone have the Mopar Part number for a Big Block Mini Starter?
Max Weg
Re: Big Block Mini Starter [Re: Max Weg] #999060
05/24/11 05:06 PM
05/24/11 05:06 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
use a stock magnum starter from any mid 90's truck... The one I picked up was from a 94 Dakota 3.8 V-6 They will fit from the slant 6 to the hemi..
Re: Big Block Mini Starter [Re: Max Weg] #999061
05/24/11 05:47 PM
05/24/11 05:47 PM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
P5007860
Re: Big Block Mini Starter [Re: camdog440] #999062
05/24/11 06:07 PM
05/24/11 06:07 PM
ok
mopdragster Offline
mopdragster  Offline
ok
Not to hijack but has anybody had any trouble with these hitting the block at the base of the starter? mine uses an adapter midplate to adapt the powerglide and it has a spacer block where it bolts to the midplate and the starter is hitting the block and kicking the starter sideways. Any ideas?
Starter is same as above
Re: Big Block Mini Starter [Re: mopdragster] #999063
05/24/11 06:35 PM
05/24/11 06:35 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I'm real Happy using starters from DB Electrical in Johnson City, Tennessee.
Just got one of their late model high torque #SND0088 Mini starters for the 12:1 414 for $76.00 shipped...no core.
Great people to deal with too, I got a 1 wire Alt from them too
WIZE
In Car:
Re: Big Block Mini Starter [Re: Bob_Coomer] #999064
05/24/11 06:42 PM
05/24/11 06:42 PM
Canada
Max Weg Offline OP
Max Weg  Offline OP
Canada
Thanks for the info I will try the magnum mid 90's one.
Max Weg
Re: Big Block Mini Starter [Re: mopdragster] #999065
05/24/11 09:15 PM
05/24/11 09:15 PM
NC
440Jim Offline
440Jim  Offline
NC
I use junk yard mini-starters from small block (Magnum) engines in my big block 727 application. I did have one block be real close from block casting flash near the transmission mating surface. A little grinding to clean up the casting flash was all it took. But since I saw that one, I clean up that area on all big blocks before I paint them...
