Re: Help me I.D. these 2 engines.....
[Re: racerAL]
#99829
08/04/08 09:13 PM
08/04/08 09:13 PM
Posts: 7,906 Lower AZ
AZ-Nick
Here Since 1996!
Here Since 1996!
Lower AZ
2120529 = 59-65 413ci.....
71 GTX 4sp Dana GY9
HD Road King
[Re: racerAL]
#99831
08/04/08 09:18 PM
08/04/08 09:18 PM
Posts: 8,680 Buford, GA
I_bleed_MOPAR
Buford, GA
Nick is correct on the RB. The /6 is a 225- I'm guessing all years of 225 used the same casting #. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: AZ-Nick]
#99833
08/04/08 09:40 PM
08/04/08 09:40 PM
Posts: 233 NH
Fastback67
NH
This is correct
[Re: ScottSmith_Harms]
#99835
08/04/08 10:14 PM
08/04/08 10:14 PM
Posts: 535 Ohio
racerAL
Ohio
thanks for the confirmation...Scott, have you had any of these early 413's sonic checked? can't you put 426 pistons in these?
-1967 Plymouth Satellite #3555 446 cid on E-85 best 1/4 et 10.577 @ 127.58 best 1/8 et 6.722 @ 100.68 best 60ft. 1.419
[Re: racerAL]
#99838
08/04/08 11:22 PM
08/04/08 11:22 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Pretty much a resto head, small valves, 4 bolt valve cover design, no big deal heads, basically identical to 516 heads, just cosmetically unique due to the lack of machined bolt holes. Mine were rusted up in the chambers so I looked for a replacement set, took a while but I found some on ebay for $75.00 complete. So, value wise? Not much, desirability wise? Depends on who needs them.
