Re: BEST BIG BLOCK HEADS FOR THE MONEY
[Re: rickb67]
#998139
05/23/11 06:22 PM
05/23/11 06:22 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I really like my home ported rpm`s..............slightly bigger than stock port and just had em freshened after 6 years and all they needed was a valve job. The guides were awesome and we put rubber seals on instead of the teflon I was running. I should be making 600+ based on my et and weight of 3150+lbs AND, I drive the hell out of it on the street.
[Re: cudaboy]
#998142
05/23/11 07:27 PM
05/23/11 07:27 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
Where are all the ProComp cheerleaders?
Dennis
yeah Pro Comp are the best bang or buck! Or the 440 Source both are from China...but so are most of the cranks and rods you buy too...so what difference does it make?
[Re: B1Fish540]
#998143
05/23/11 09:00 PM
05/23/11 09:00 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
After you buy a set of heads and have to have them maxx out to get enough CFM you end up with about the same $$$ as a set of 440-1 heads. And later if you ever need more cu. in. & you will,you won't have to buy new heads again. The only problem I have ever had with Indy,is breaking parts from the power they make.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: rickb67]
#998152
05/24/11 02:40 AM
05/24/11 02:40 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
The Edelbrock Max Wedge victors are decent for the price, but not without some issues. The heads with valves from Edelbrock are setup for stock valve spring heights. If I used them again, I would get the heads without valves, then get longer valve. Because the longer valves will change the rocker geometry, mill off the rocker stands and use the maxwedge style rocker shaft hold downs. On my 4.15" stroked 400 block (about 500"), with the KB/ICON flat top pistons it has about 12.4:1 compression. The pistons could use deeper valve pockets if you are going to run a cam with 270 or more duration @ 0.050. I'm running a 264@0.050" cam and the engine makes over 650 HP.
[Re: Biginchmopar]
#998153
05/24/11 02:58 AM
05/24/11 02:58 AM
451Mopar
Aurora, Colorado
B1BS HEADS ARE GREAT TOO.IM MAKING 842 HP WITH THEM.
I would second that!
Brodix makes the B1-BS head and I have never had a problem with them. They are real good if you open them to the Max Wedge port.
The B1-BS heads are good, but the small 65cc chambers would make a 500" engine with flat top pistons about 13.9:1 compression, which may be good if using race gas (or not too good if using pump gas?). OOB they don't flow much different that a RPM head, but can be ported to over 350cfm with maxwedge port size.
I have a set of used B1-BS heads with one damaged port/chamber. I was going to have them rebuilt and ported, but got the Victor heads. If your interested in the used heads, I'll sell them for $1,000 (Less than the cost of one new bare head.) Here is a pic of the bad chamber:
[Re: Cab_Burge]
#998157
05/25/11 03:56 PM
05/25/11 03:56 PM
Thumperdart
State of confusion
My stroked 400(470)went 10.40`s w/traction issues and made 614hp-580tq w/906`s and a 590-605 solid Isky cam.
