Page 1 of 3 1 2 3
BEST BIG BLOCK HEADS FOR THE MONEY #998119
05/23/11 12:45 AM
05/23/11 12:45 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
I HAVE STAGE VI HEADS AND I AM NOT HAPPY . 125 PASSES AND HAVE HAD TO REDO THEM TWICE AND THE INTAKES ARE SUNK IN THE HEAD. JUST SO I DON'T SCREW UP AGAIN. WHAT SHOULD I BUY.
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: rickb67] #998120
05/23/11 12:51 AM
05/23/11 12:51 AM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Indy sr's or ez heads that use standard rockers.
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: rickb67] #998121
05/23/11 12:58 AM
05/23/11 12:58 AM
fullmetaljacket Offline
Indy Sr's or the EZ's for a relatively stock looking head after the Indy logos are ground off. Hide the oil feed lines in the rear and pop on some stock valve covers and you're in like flint.
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: fullmetaljacket] #998122
05/23/11 01:17 AM
05/23/11 01:17 AM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
How much Horsepower do you want to make, and how many cubes???
No "one answer" for all applications...
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: cudabin] #998123
05/23/11 01:27 AM
05/23/11 01:27 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
440-1s
aready had the indy sr,s
and moved up to the 440-1 cnc 345s
1.39 9.85 - 137 mph
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: cudabin] #998124
05/23/11 01:38 AM
05/23/11 01:38 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Would like to be around 650 horse. Next engine will be a 500 incher.
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: rickb67] #998125
05/23/11 01:56 AM
05/23/11 01:56 AM
gregsdart Offline
gregsdart  Offline
500 cubes is borderline between SRs and 440-1 heads, or B1s. Each will do a good job for a certain application. If you get a copy of AndyFs book How to Build max-performance mopar big-blocks, he has a chart of the three most common port sizes and where the torque peak comes on for each at different motor size.
I would be shopping for Eddys up to 675 hp, Indy heads or Eddy Victors for 700 to 900 hp, or if I am going for 900 hp and above, B1s.
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: gregsdart] #998126
05/23/11 01:59 AM
05/23/11 01:59 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mopar Performance
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: gregsdart] #998127
05/23/11 02:39 AM
05/23/11 02:39 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Where can i find that book. might answer a lot of questions
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: rickb67] #998128
05/23/11 03:29 AM
05/23/11 03:29 AM
Edelbrock RPM heads CNC ported by Modern Cylinder heads will make that power no problem on a pump gas 500 inch motor Been there, done that I have made 625 Hp with a set of standard 440 port size 906 on a high compression bracket race 452 CI motor and a little more HP on race gas using a non ported set of B1-BS heads with standard 440 port size heads on another bracket 452 C.I.440 motor The block becomes the limiting factor when you start getting above 650 HP on the high deck Mopar blocks
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: Cab_Burge] #998129
05/23/11 03:45 AM
05/23/11 03:45 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
my home port SR's made 650 hp with a streetable solid cam in my first 451. that got my'71 'cuda down to 10.7@127mph in street trim. std Hooker headers work with the low deck Indy heads too.
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: rickb67] #998130
05/23/11 10:04 AM
05/23/11 10:04 AM
gregsdart Offline
gregsdart  Offline
Amazon carries it, another great book is Big block Mopar performance, by Chuck Senatore. Both worth reading over and over.
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: gregsdart] #998131
05/23/11 12:24 PM
05/23/11 12:24 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
Where are all the ProComp cheerleaders?
Dennis
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: cudaboy] #998132
05/23/11 12:29 PM
05/23/11 12:29 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
B1BS HEADS ARE GREAT TOO.IM MAKING 842 HP WITH THEM.
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: moparniac] #998133
05/23/11 12:44 PM
05/23/11 12:44 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As stated it will depend on the desired application for the engine in question. Greg's outline is pretty much what we follow. Hard to beat the Edelbrocks for value. I have no first hand experience with the 440 source heads but I would think they would be pretty hard to beat as well for anything in the 600-700hp range. Provided they get a good bill of health. If it is primarily a street car I think I would want to keep the port cross section smaller to make it a more street friendly set up, especially in a heavy car. I had very good luck with Indy SR's in my Belvedere. It was 3770lbs with a 451 and SR's with the std port size and the car went 10.50's on pump gas. Worked very well for me..
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: rickb67] #998134
05/23/11 04:09 PM
05/23/11 04:09 PM
AndyF Offline
AndyF  Offline
650 hp can be done with ported Edelbrock heads if that is as far as you want to go. If you want to step the engine up in the future then a set of Indy EZ heads would be a better strategy. The EZ heads are good up to 800+ hp which is then where you need an aftermarket block.
Read the book, I covered this topic in there in a lot more depth.
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: AndyF] #998135
05/23/11 04:11 PM
05/23/11 04:11 PM
AndyF Offline
AndyF  Offline
The Stage VI heads are good once you get them fixed. Dwayne can take care of them for you but it will probably cost as much to fix them as it would to just by a set of RPM heads. Tough choice to make, especially if you need to by a new intake manifold.
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: cudaboy] #998136
05/23/11 04:31 PM
05/23/11 04:31 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Dennis
i would try the Procomps after Jeff at Modern has stated several times here that he can get big flow numbers out of them
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: sixpackgut] #998137
05/23/11 05:29 PM
05/23/11 05:29 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
I have had most all of them except the exotics....street friendly...Indy SR all the way and dont look back. Great head.
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: 2QUICK4U] #998138
05/23/11 06:16 PM
05/23/11 06:16 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I would second that!
Brodix makes the B1-BS head and I have never had a problem with them. They are real good if you open them to the Max Wedge port.
Page 1 of 3 1 2 3
