HiYa all, I had the pieces lying on the garage floor for so long, I shouda wrote eveything down!
Those two black spring clips ( the ones that want to slice your finger to shreds) that hold the clutch pedal rod to the Z-bar and the other "adjusting rod on the other end of the Z-bar, my question is: On that spring clip, does all 4 ends of the spring clip go "under" the lip or does only 2 ends go "under" the lip to fasten it together? Only pressing the two end clips under the lip, it spins so loose I wasnt sure, so I tried to force all 4 spring ends under the lip, almost shredded my fingers but "got er done" and it's a really tight fit. Whats the correct way to do this? Ya know, alzheimers really sucks! Thanks veru much! MoPar to ya!
