Valve Stem Seal #997770
05/22/11 09:58 PM
05/22/11 09:58 PM
Northern Virginia
barracuda7 Offline OP
Northern Virginia
I bought a new set of Valve stem seal for 906 head. In the box, there are 2 different type of Valve stem seal, 1 is soft and short + 1 is hard and longer. Nothing look like an old one I removed, which is same for both exhaust and intake.
Those Seal I bought look like the picture below. My question is hich one for Intake, which one for Exhaust?
Re: Valve Stem Seal [Re: barracuda7] #997771
05/22/11 10:01 PM
05/22/11 10:01 PM
md
W
wicked Offline
wicked  Offline
W
md
The one on the left is typical exhaust stem seal
Re: Valve Stem Seal [Re: barracuda7] #997772
05/22/11 10:10 PM
05/22/11 10:10 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
That's correct, the deeper one is intake seal.
Re: Valve Stem Seal [Re: barracuda7] #997773
05/22/11 10:20 PM
05/22/11 10:20 PM
Northern Virginia
Northern Virginia
You guys awesome!
Thanks a ton!
Re: Valve Stem Seal [Re: barracuda7] #997774
05/23/11 10:11 AM
05/23/11 10:11 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Yes correct, the short seal is the OEM style for the exhaust.
The black Nylon plastic seal is OEM for a Small Block Chevy.
Do yourself a favor and put the positive style OEM seals on the intake side at least
