727 front pump alignment #997766
05/22/11 09:51 PM
05/22/11 09:51 PM
md
W
wicked Offline OP
wicked  Offline OP
W
md
Best way to accomplish aligning the pump halves? I didn't come up with much info on a search.
Re: 727 front pump alignment [Re: wicked] #997767
05/22/11 10:36 PM
05/22/11 10:36 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
727 does Not need a pump alignment, solid front with bolt on pump support
But 904 does have two pump half's that can be aligned by sight, big hose clamp around the out side works also
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: 727 front pump alignment [Re: moparts] #997768
05/22/11 10:47 PM
05/22/11 10:47 PM
md
W
wicked Offline OP
wicked  Offline OP
W
md
ok thanks, wasnt sure, been a long time since I'be been in one
Re: 727 front pump alignment [Re: wicked] #997769
05/23/11 08:32 AM
05/23/11 08:32 AM
Australia
fullonmopar Offline
fullonmopar  Offline
Australia
I put the 904 pump into the trans housing backwards with no outer seal and with the bolts lose, then tighten the bolts, the trans housing aligns it all up for you. Using an old housing is ideal as you don't have any guts in the trans to get in the way or do it with the original housing before any assembly.
