Re: Mopar 508 cam in a small block...how much compression ?
[Re: DusterKrazy]
#996591
05/21/11 03:36 PM
05/21/11 03:36 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
12 to 1 would be good but you don't HAVE to have compression to run a large hyd cam. Lot's of converter 4800/8"(NO street converter) and 4.30-4.56 gears with 26-28" tires.I've run high 11's with that cam 9.8to 1 compression,3000converter,3.91 gears. Changed gears,converter,added a point of comp and gone low 11's. A body 3100lbs and 360w/factory heads.I'd suggest a GOOD hyd cam from Bullet cams,ask for Tim.It's cheaper to put the right cam in it than gears,converter,etc.
[Re: sshemi]
#996592
05/21/11 04:31 PM
05/21/11 04:31 PM
Posts: 3,445 N.Wilkesboro,NC
DusterKrazy
N.Wilkesboro,NC
do you already have the cam? I find a bit too much for the street. I had it in a well built 340 and had prblems making it run good because of the low vac.
Yes, I already got it. 12.1 compression would impossible to deal with on the street.
[Re: goldmember]
#996594
05/21/11 05:58 PM
05/21/11 05:58 PM
Posts: 2,128 sweden
sshemi
sweden
Well if you think that comp would be too much,do you have enough converter,gear,etc? If not get better matched cam and sell the .508.
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: sshemi]
#996595
05/21/11 09:06 PM
05/21/11 09:06 PM
RapidRobert
#1 What fuel are you planning on? I'd say 9.5 or more and leaving room to max out the timing curve will give you way more gain than a too high CR that makes you compromise the timing. Def measure/calculate during mockup/planning & get the ACTUAL CR
[Re: Kern Dog]
#996597
05/22/11 01:42 AM
05/22/11 01:42 AM
DusterKrazy
N.Wilkesboro,NC
I have this cam in a 9 to 1 360 with iron heads. Its in my FrankenDuster. I have a 4 speed and 3.55 gears. It idles decent and runs strong.
I bet it chops pretty good...
[Re: DusterKrazy]
#996600
05/22/11 01:26 PM
05/22/11 01:26 PM
Posts: 5,270 Missouri
MY340
Missouri
I had the MP508 in my old Duster 340-4psd-4.10 gears with 10-1 compression. It ran great & sounded wicked at idle but I got old and went to an automatic on my present car. ![](/ubbthreads/images/graemlins/biggrin.gif) 22 degrees intial timing 36 total timing all in by 2200rpm
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
