Re: E body sway bar mounting brackets? Need wider/c pics?
[Re: RUMBLON]
#996149
05/21/11 03:34 PM
05/21/11 03:34 PM
Posts: 120 North Seattle, Washington. USA
U code RR
Well you could do what I did when I upgraded my 71' Challenger R/T suspension. I ran into the same problem, so I simply removed the mounting brackets from the K-frame(the ones you have circled in your pic),turned them over so the flat surface was now the mounting surface for the swaybar isolators, mounted them back on the K-frame with longer bolts,Done! 10 mins. ZERO $!
When seconds count...
The Police are only minutes away.
Smith and Wesson are your friends.
