Most streetable stroker 400 or 440
#996083
05/20/11 10:51 AM
05/20/11 10:51 AM
Posts: 4,046 Minnesota
72blubird
Minnesota
I am going to build a stroker motor and want something that will run on pump gas and not overheat. I will use it for occasional track days and car shows. However for me to do either often means 100 mile or more round trips. I need something streetable even if I get into bumper to bumper traffic.
Need ideas a on which motor and kit would be best for my needs thanks.
What was I thinking....
Re: Most streetable stroker 400 or 440
[Re: AndyF]
#996085
05/20/11 12:15 PM
05/20/11 12:15 PM
Posts: 75,139 A Banana Republic near you.
JohnRR
A 440 block with a 4.25 crankshaft is a very simple combination. Use Edelbrock RPM heads, keep the compression down around 10:1 or less and run a mild hyd roller cam with a RPM Performer intake manifold. That combination will give you a lot of low end torque with very smooth performance.
Just don't go crazy with the camshaft or compression. People will try to talk you into building a race motor so you have to ignore them if you want a street motor. Look at the specs on the Chevy 502 crate motor. That engine is a good example of a streetable stroker.
What he said , to get the compression low enough it's going to require a piston with a D shaped dish, the piston wants to be at zero deck using a .041 head gasket .
[Re: 72blubird]
#996086
05/20/11 12:30 PM
05/20/11 12:30 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
I drive mine every day.
440 block 4.25" crank 7.1" H beam rods 17cc dish pistons = 10.3:1 Edelbrock RPM heads M1 intake (was using an RPM intake) Mopar 528 solid flat tappet camshaft Crane ductile iron rockers 1.6 ratio
Real nice to drive on the street with 15 inches vacuum at idle. I originally built the engine with a Comp XS290S camshaft, 9 inches of vacuum at idle and not so nice to drive on the street but I did for 3 years. Car weighs 3800# with me in it and runs very low 12's at 116mph.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
[Re: Mick70RR]
#996087
05/20/11 02:04 PM
05/20/11 02:04 PM
Posts: 2,648 GA
Boosted
GA
Mine is a street car also..
512 11 to 1 MP Stage 6 heads ported MP 590 purple shaft solid lift M1 1050 Dominator...
I love it..
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
[Re: AndyF]
#996089
05/20/11 05:02 PM
05/20/11 05:02 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I'd lean towards the 440 based one, the additional deck height will help with compression height to get the pin out of the oil ring, and longer rods to reduce side loading on the cylinders. should make for a more durable combination if you plan on putting miles on it and not tearing down/refreshing every 30k miles....of course, on further thought, a stock 454 has a 4" stroke, 6.135" rod, with a 9.8" deck height, and they seem to last a while....rod ratio/side loading on a 454 (RR1.53) would be the same as a B block combo and a 4.15" crank (6.358 rod, 4.15 stroke = RR1.53)
I'd probably look at a 4.15 or 4.25" stroke, an edelbrock head, ~10:1 compression, and something like a comp XE285HL cam....
[Re: Boosted]
#996092
05/20/11 06:07 PM
05/20/11 06:07 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I love it..
Are you sure you drive it on the street? Sounds like a race motor to me... ![](/ubbthreads/images/graemlins/eyes.gif)
Yes, Im being sarcastic!!!
Sounds like a tight combo. ![](/ubbthreads/images/graemlins/thumbs.gif)
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#996093
05/20/11 07:48 PM
05/20/11 07:48 PM
Posts: 9,894 Weddington, N.C.
Streetwize
Weddington, N.C.
I've built every R/RB combo from 451/470/496/517 low decks and numerous 493-508" RB's. ![](/ubbthreads/images/graemlins/Twocents.gif) The easiest and best 'bang for the buck' RB combination to build the 4.25 stroke RB using the 2.200 rod journal. a 4.15/2.375 isn'tmuch harder but it takes more clearancing around the bore bases and the oil pickup. and all else being equal, 12 cubes is another across the range 15-20 lb/ft for really no more extra $$$. B's are trickier (when starting with an RB counterweighted crank) but The best B (again bang for the buck) and ease to assemble) is the 470. It's just a great overall combination that's worth the extra $$$ over a 451 but at the same time produces about the same power (though as little less torque) as a 4.15 stroke 496 by it's ability (or willingness) to wind up a little tighter....provided you've got the valvetrain to let it. Either way, I keep the compression sensible with a D dish 10.5:1 compression, and prefer at least a decent set of mildly ported E-heads and top it off with a ported street dominator/Performer RPM or Indy dual plane (if you can find a good casting) and at least an 850DP. For a cam a good hydraulic 'default' is the old comp 305 (253@.0500 or the XE 251/257 @.050 grind. For added upper bottom through the top a Bullet Hydraulic roller with similar @.050 lobes will be bigger in the .200-up range which will really let the smallish standard port motors get a little more air which equals VE which equals TORQUE, with no drivability downside. 2" x 3 1/2" header and a free flowing 3" exhaust and you're pretty much set. To go bigger than about 255 @.050 hydraulic (or around 262-265 solid flat tap) you'll really want to bump up the CR to offset the loss in vaccuum signal, it takes a bit of expertise with matching the components to run the higher CR's so we'll leave that for another day. But the basic recipie outlined above can get you 585-620HP with way more torque from 3000 up than you can hook up....and a high gear roll-on that will pull like the passing gear of a well tweaked 440. Also you don't need lot of stall for one of these combos to work, just spec a tight 9 1/2-10" (depending on MFG) it to stall around 3200 and flash to about 4000-4200 and find something to hang on to.
