battery keeps dying #995686
05/19/11 01:36 PM
05/19/11 01:36 PM
MI
Moparmadness72 Offline OP
MI
hey guys I just bought a new battery for my 72 Dodge Charger and i have to jump it every time to get it to start and as soon as i shut it off it wont start again. I disconnected the battery while the car was running and it didn't shut off so i know the alternator is good. Does anyone know anybody know if this is a common issue? Any ideas would help A LOT. Thanks moparts!!
Re: battery keeps dying [Re: Moparmadness72] #995687
05/19/11 01:58 PM
05/19/11 01:58 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Did you check your grounds?
Re: battery keeps dying [Re: Todd] #995688
05/19/11 02:03 PM
05/19/11 02:03 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
You do have a good ground from the rear of the engine to the body don't you??
Re: battery keeps dying [Re: MoparforLife] #995689
05/19/11 02:32 PM
05/19/11 02:32 PM
MI
MI
yeah, but where are the main spots to check for grounds? Its a 340 block.
Re: battery keeps dying [Re: Moparmadness72] #995690
05/19/11 02:41 PM
05/19/11 02:41 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
do you have a consatnt draw? New radio? alarm? How's your alternator? I'd measure the back of the alt and at the battery and see what numbers you are pulling. Maybe your trunk light is stuck on...just kidding
Coming soon!!!!
Re: battery keeps dying [Re: Mr.Yuck] #995691
05/19/11 02:45 PM
05/19/11 02:45 PM
MI
MI
the alternator is new, no new radio or alarm or anything like that. I can turn the headlights on with the battery, but when i go to crank it, the headlights dim a lot.
Re: battery keeps dying [Re: Moparmadness72] #995692
05/19/11 02:55 PM
05/19/11 02:55 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
was the problem there before the new alt? I'd still take a volt meter and start at the back of the alt and work your way to the battery
Re: battery keeps dying [Re: Moparmadness72] #995693
05/19/11 03:09 PM
05/19/11 03:09 PM
Upper Midwest
Upper Midwest
Never to many grounds.
Not out of the question to have a bad battery. Even new. Make sure that all the connections are shiny clean, scrape new posts too to get protective coating off, scrape terminal clamps shiny clean too, Make sure that they are tight. Take out eh bolt and squeeze clamp in vice or with vice grip, Run a hack saw down split, put bolt back in and tighten down. Now it will get really tight.
Re: battery keeps dying [Re: Moparmadness72] #995694
05/19/11 03:31 PM
05/19/11 03:31 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
How long between jumping it, shutting off, and the no-start? If it's just a few minutes, you have connection issues between the battery post and the cables. If you happen to be using the 'twisty-push' method of putting battery connections on that can cause a no-start right after you jumped it. Otherwise, I can't recall having a battery so bad that I could jump-start the car and have it not re-start at least once.
As an FYI, there are recommendations to never do this. Pulling a terminal causes a big voltage spike in teh system, and the battery acts as a buffer. But if you disconnect the battery, your buffer is gone, and who knows where teh voltage spikes will go.
With that said, I've done this many times over the years with no troubles. And I've also learned better ways to verify/diagnose a charging system, too.
And the disconnect method only means that the alternatory is supplying enough to keep teh car running at idle, it does not mean the alternator can supply enough to support all teh vehicle accessories during a trip and permit a restart afterward. BTDT.
Re: battery keeps dying [Re: Moparmadness72] #995695
05/19/11 04:15 PM
05/19/11 04:15 PM
Put it on a fast idle & see what (charging) voltage you have at the posts. Then as said see if you have a draw anywhere by w it "not running" take off a batt terminal from either post at night & see if there's a miniscule spark or use your meter. The batt is always the 1st suspect but w it new I'm assuming it is good and that the prob existed b 4 & you got a new batt & still no resolution EDIT when you check your charging voltage you need to have it fully charged to get an accurate reading & w it being run down you'll get a false high reading till it's fully charged
Re: battery keeps dying [Re: Moparmadness72] #995696
05/19/11 04:43 PM
05/19/11 04:43 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
WHERE did you buy the battery? Some of the retailers have a free service that will do a basic electrical check.
Re: battery keeps dying [Re: dOc !] #995697
05/19/11 06:37 PM
05/19/11 06:37 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Check how many volts the battery has at rest. Should be more than 12 V, if not charge it until it does. 2) Start the car, if you can. If when you try and it does not start, the volts dropped below say 11, then the battery is probaly junk. 3) Most auto part stores have a meter to check "load" and how many amps is being starved (you did buy a battery that puts out 600 amps or more and more than 800 on a HP motor, and by the way, more than 1100 if it is in the trunk?). 4) If it starts and you run for a awile, put the gage on the battery whiles it's running and see if it is charging at somwwhere around 14V. 5)Shut off the car, check the volts every 15 minutes to see if there is a major drop, if so there is either a drain somewhere, and disconect the battery and check every 15, if it drops alot then, it's junk.
But the way the starter could be going and it takes alot of amps to get it going, and when it gets hot, it takes more.
Re: battery keeps dying [Re: DANA60] #995698
05/19/11 07:15 PM
05/19/11 07:15 PM
California
mickm Offline
mickm  Offline
California
i had an alternator that checked out fine, volt wise. it was putting out plenty of volts, and almost no amps. i discounted that as the problem as i had checked all that, until it completely died. i found out by having it tested at a shop that could test the amps as well.
Re: battery keeps dying [Re: mickm] #995699
05/20/11 02:41 PM
05/20/11 02:41 PM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
You didn't mention if was a sealed lead acid or not. A few years ago I had two brand new standard, (wet), lead acid batteries from auto parts stores with bad cells. Haven't seen a new sealed one bad yet, but it's possible, as was said have a parts store run it on the diagnostic machine.
